Online: Retroman, B0nes
Hot Pipes!
  • pogmahon
    pogmahon
    18 years ago
    Well the Deuce is here and its the love of my life but the exhaust pipes are very unforgiving as i found out the first time i wore my Dririder Rallycross Evo's ... they are fairly flaired at the bottom to allow high boots to be worn underneath but as a consequence they rub against the pipes when stationary or manoevering into a parking spot etc.... End result is severe burning and several holes on their maiden journey.... LOL I'm not sure if it's worth getting a heat proof panel sown onto the lower section or look for something a little more tolerant to the occasional brush with hot pipes. Anyone suggest or recommend something which they have found to do the job?
    Cheers Graeme
  • Magilla
    Magilla
    18 years ago
    Its mandatory to have calf burns, burnt boots, pants etc  when owning a Harley.
    You will learn eventually
  • pogmahon
    pogmahon
    18 years ago
    LOL..... i'm beginning to think you may be right on that one :)
  • shadowhand
    shadowhand
    18 years ago
    Black exhaust/header wrapping held in place with metal tie (like the exhaust ties which hold one heat covers) with a screw to tighten the bracket.
    Wrap it around the hot pipe with a third overlap only.
