  • cloudi2
    cloudi2
    i'm about to change to an inverted front end but don't want any more rake than what comes standard on the bike .can anyone tell me what degree of rake the softail custom fxstc 2008 model comes with ? the inverted front end is an ultima front end comments please good or bad ,thanks in advance for your info
  • hd888
    hd888
    just changed mine over as well, looked into it pretty deep and heard a few bad reports about ultima. I went for a mean street front end. 3 degree rake and am very happy with it. You can check it out in the bike of the forum pics. pretty sure Parts-Pro are dealers for Mean Street products.
    Ultima / Mid West 58 mm Inverted is only available in O or 5 deg
  • kiteman
    kiteman
    HD site shows ST Custom at 32.3 degreees rake and Rocker at 36 degrees. It's shown under "Full Specs & Pricing" for each of the models. Not sure that helps at all......
  • Deadly
    Deadly
    This is the HD inverted front end
    Standard rake
    Better handling
