Online: Merv
White Wall Tyres
  • Finny
    Finny
    Can anyone that has white walls , Please tell me what they use to keep them white?
  • Paul.C
    Paul.C
    Finny,
    I don't have them, but maybe white shoe polish would do the trick !!!!
  • Hoodaman
    Hoodaman
    gumtion or whatever its called works well..........and mine are WHITE...........lol
  • jacks
    jacks
    Hi Finny, try Handy Andy (Powder) with a stiff scrubbing brush.....works wonders.....I jack the old girl up and it's a breeze, at the same time I use the Californian Purple polish on the wheels........maaaggic...better than new....make sure that you dry around the rim, otherwise it will streak............
  • Finny
    Finny
    Someone told me to use Jiffy but i thought they were joking.........But thanks to you all and ill try em
  • Cranky
    Cranky
    Yeh I have heard of people using That Jif stuff on em. mainly older shovels to remove the grease and grime
  • ductor
    ductor
    Try degreaser , I used to use the pink stuff on my whitewalls , scrubed them with a toilet brush (right length and shape) and they looked bright for a couple of weeks
    Ductor
  • houli
    houli
    An old hot rodder i work with swears by Napisan,(the stuff you can buy in the nappy isle at supermarkets) keeps at me to clean mine but i kinda like the yellowing that comes with age.
  • KDh Kustoms
    KDh Kustoms
    When i had white walls i used mr sheen its cheap and easy I use it for the whole bike from paint to chrome.(except the seat if you do that you will slide around all over the place)
    Doug
    KDh Kustoms
  • Firey
    Firey
    The young fella who fitted my white walls told me to use Jiff, works for me
  • Finny
    Finny
    Cheers guys ..........I tried gumption with just a wet cloth , Hardly any scrubbing and they come up a treat.....And only $5;38 a tub
  • wolfgang1
    wolfgang1
    I got them and yes I use jiff and a plastic brush and I changed the breakpads to some harder once leaves less of a mark on the whitewalls after a few rides.
  • FLSTC
    FLSTC
    forget about elbow grease my friends .. courtesy of scotty last year i got a set of Lindall brake pads reputedly that left no brake dust.  I just went 12,000 k's on my Metzler ww without ever feeling the need to clean !  you crazy not to change to these in future if you like your ww's
  • wolfgang1
    wolfgang1
    Thanks .......... I will keep it in mind for my next break pad change . all this cleaning of ww tz tz tz......................... should be on the road and enjoy the ride . Thanks again.
  • Springer_13
    Springer_13
    I have white walls on my car.............I use..........thinners................wipes on and off with ease!!
