Online: beaglebasher
SPECTRO Premium Oil's.... For Harley Davidson's
  • bozhog
    bozhog
    NOW IN STOCK READY FOR DELIVERY DIRECT TO YOUR DOOR:
    Premium SPECTRO oil's & Fluids for your HARLEY- DAVIDSON...
    Also Genuine HARLEY- DAVIDSON oil filters...
    SPECTRO Platinum Full Synthetic 20w-50 Motor oil
    (You Cant Buy Better Synthetic Harley V-Twin Motor oil)
    SPECTRO Heavy Duty 20w-50 Motor oil
    (Formulated For All Harley Davidson V-Twin Engines - Any Year Without Restriction)
    SPECTRO Platinum 6 Speed Full Synthetic Gear oil
    SAE 75w140 / GL-5
    (The Best Oil For The New Harley Davidson 6 Speed Transmissions)
    SPECTRO Gear Guard... SAE 85w140 / GL-5
    (Recommended For All Harley Davidson BigTwin Transmissions of Any Year)
    SPECTRO heavty duty Primary chaincase oil... SAE 85w
    (Formulated Especially For All Harley Primary Chaincases & Sportster Transmissions)
    For all your Harley Davidson oil requirements in one place....
    PM...bozhog
    or click on this link below.....
    bozhogsharleyoilworks.blogspot.com
     Deliveries Arranged Australia Wide By... IPEC or Australia Post ...
    This is Just Some of The Products Available in The SPECTRO Range of Oil's & Fluids ...
     Product Information :
    Heavy Duty Platinum Full Synthetic 20w 50
    Heavy Duty Platinum Full Synthetic is engineered specifically for Harley high-performance engines and other high output V-twin Motors. Heavy Duty Platinum Full Synthetic provides smoother shifting, reduces friction, offers tremendous lubrication and provides superior protection in extreme heat conditions. A.P.I. SF/SG - diesel-rated.
    Unlike many so-called synthetics, Spectro Heavy Duty Platinum Synthetic is a true synthetic, crafted on a batch-by-batch basis from modern Group IV PAO ( polyalphaolefin ) synthetic base Stocks.
    You can't buy a better Oil !
    Product Information:
    Heavy Duty Engine Oil 20w 50
    Spectro Heavy Duty Engine Oil is a superior premium motor lubricant designed specifically for use in American made Harley V-Twin engines. Crafted from superior petroleum stocks combined with the most advanced anti-wear, anti-carbon additive systems available, spectro Heavy duty extends component life, reduces wear, eliminates valve sticking. meets all known OEM warranty requirments. Exceeds A.P.I. SF/SG-CD/CG - 4
    Heavy Duty Platinum Full Synthetic 6 speed Transmission Lube
    Designed by Spectro in response to complaints from Harley owners about the great but noisy new 6-speed transmission, this full synthetic provides ultimate lubrication protection. Formulated to significantly reduce gear noise and provide easier, smoother shifting, this SAE 75w140 formulation eases shifting even when cold. High loads and extreme heat do not affect the oil, so it performs well when pushed hard and long. A.P.I. GL-5 rated
    Heavy Duty Primary Chaincase Oil
    This sheer stable petroleum is designed to withstand the punishment of high loads, and contains special polymers to provide exceptional clutch engagement and temperature stability. Meets full OEM requirements, and should be used according to manufacturer’s instructions. Formulated specifically for Harley® Sportster and Big Twin applications. Low drag, low friction loss SAE 85w viscosity eliminates clutch “drag” and slipping.
  • bozhog
    bozhog
    Heavy Duty Platinum Fully Synthetic 6 Speed Transmission Oil
    Heavy Duty Platinum 6-speed Transmission Oil
    Product Information...RRP 1 US Quart $34.99
    Heavy Duty Platinum 6-speed Transmission Oil... Also Suitable For The 5 Speed Transmission
    There Is More To A Transmission Than Just Metal
    As a company tenaciously focused on any improvement to the American Big Twin drivetrain, BAKER Drivetrain recognizes the fluid in the transmission is key in the performance and life of a transmission. It is a mechanical part of it as much as the gears, case, bearings, etc…so it must be of quality. The Spectro Platinum Heavy Duty 6-Speed Transmission Lubricant meets our BAKER Drivetrain quality standards for recommended transmission oil. Our standard for recommending oil is that it must have optimized properties tailored only for components in a V-Twin motorcycle transmission and it must exceed all others in excellence – like our own products do. Cheaper oils cannot provide all these qualities.
    Spectro’s 6-Speed formula base is synthetic group 4 base stock which is the highest rating for a synthetic lubricant. It is pure with absolutely no petroleum product blended into it. Unlike most others, the oil carriers for the anti wear and friction modifiers are 100% synthetic making this oil truly 100% synthetic which means this fluid cannot be worn out or broken down - it can only be contaminated. For example, in a hermetically sealed application it would last for 20 years, but transmissions are far from sterile because the vent breathes air as the transmission heat cycles and the seals are not perfect. For this reason, we advise changing your oil every 5000 miles or once yearly, whichever comes first. It’s worth the investment protecting your premium transmission.
    All anti-wear ingredients are additized to a factory fill specification. Additives include zinc as an anti-wear additive, phosphorous as an anti-wear and friction modifier, and sulfur as an anti-wear and friction modifier. Note; sulfur cannot be used as an additive in multi-use oils that are used in the engine sump because sulfur gets contaminated by the combustion process and eventually changes into sulfuric acid. Spectro’s special formula also protects against long term seal leaks by maintaining seal elasticity, as validated by Buna-N testing.
    Spectro has maintained the highest quality motorcycle oils since 1966. Spectro’s reputation may be new in the American V-Twin motorcycle industry for now, but we have discovered Spectro’s recent entry into this market as an absolute winner. They used their resources, experience, and talent for a formula specifically tailored for our bikes. As drivetrain innovators we are proud to be the ones to discover, introduce, and endorse this lube. We are equally proud to announce that Spectro 75W140 is approved by BAKER Drivetrain for use in all BAKER transmission products and we reflect that by including a free bottle in our DD6 transmissions for your best performance and convenience.
  • bozhog
    bozhog
    Heavy Duty Platinum Fully Synthetic 20w50
    Product Information...RRP 1 US Quart $21.99
    You can't bu
  • bozhog
    bozhog
    Heavy Duty Standard Engine Oil 20w50
    Product Information
    RRP 1 US Quart $10.99
    RRP 1 X 4 US Quarts $36.99
  • bozhog
    bozhog
    Heavy Duty Primary Chaincase oil
    Product Information ...RRP 1 US Quart $14.99
  • bozhog
    bozhog
    Hi guys..
    Just a reminder to all those that like to do there annual Harley oil servicing over the Christmas break ... to place there oil order early enough for delivery before the public holiday close down over Christmas so your bike is best protected & ready for this new years hot weather riding....thank you to all my customers over the past year for your support...& safe riding in the new year to all forum members....I look forward in continuing to provide all Harley owners the best premium oil's for your pride & joy in the new year...for all your Harley Davidson oil supplies go to bozhogsharleyoilworks.blogspot.com
    Kind regards & merry christmas ....:Bozhog
