Online: bikenut57, Hilly
What is a reasonable idle speed
  • wildchild
    wildchild
    On warmup motor idle is around 1300rpm, as it warms up it drops to 1000rpm.
    When I pull up at an itersection idle is around 1050 to 1000rpm, varies a little at times.
    Although it does sound like it is idling a little on the high side.
    On the twin cam 96 cube what is the lowest idle speed you can run before it effects the charging system or anything else.
  • wildchild
    wildchild
    Thanks for the replies, went for a ride today and all is good...will leave idle set at 1000
