Stem seals
  • weasel
    weasel
    My bike uses oil 10m/m on dipstick in 500kms
    And have been told puffs a bit of smoke when changin gears (thats what mates are for)
    Its an 05 fatty /carby
    And i read  that the stem seals were the problem but cannot find it i think (viton?)
    Also do the heads have to come off to change the seals
    Or has anybody heard of them being done without
    Your thoughts would be appreciated
    weaz
  • carlos1340
    carlos1340
    Weaz,
    this is the Tech Tip issued by HD to rectify the "dodgy" valve seals fitted to early 2005 Big Twins.......if you don't fall to sleep before you get to the bottom, basically, it's heads off, and new valve seals - part no 18094-02A.........
    August 10, 2005
    Diagnosing Oil Consumption
    There has been a rise in oil consumption complaints on
    2005 – 06 model year vehicles. The intent of this Tech Tip is to help you determine if there is an actual oil consumption issue and more accurately diagnose the root cause.
    1. First, determine if there is excessive oil consumption by analyzing the customer complaint and vehicle condition.
    • Many times fuel delivery related issues cause smoking complaints and may even gas wash cylinders leading customers to believe they have an "oil burner" on their hands.
    • Is the vehicle modified and what is its state of tune?
    • Does the EFI calibration match the actual components on the vehicle?
    • Is there fuel stand off in the air cleaner or manifold?
    2. What is excessive consumption?
    • Customers may not realize that all engines have some normal rate of oil
    consumption, and air cooled engines are more prone to use some oil in the course of normal operation. It would not be unusual for a Twin Cam engine to use one quart of oil in 1500 miles or a middleweight powertrain to use one quart of oil in 1000 miles.
    • Oil consumption is impacted by engine condition, mileage, duty cycle (how the vehicle is operated and in what environmental conditions), and accessories.
    • Is the vehicle through its break-in period? Remember rings must seat before they will begin to seal the cylinder to piston clearance.
    • After a discussion with the customer on the complaint and a brief inspection of the vehicle you should be able to determine if you a dealing with a rich condition, oil consumption complaint, or customer misperceptions.
    3. Determine the real rate of consumption.
    • To determine the rate of oil consumption bring the oil level to the full line following the "Checking With Warm Engine" procedures outlined in the service manual and tape the filler neck closed.
    • Have the customer ride the vehicle and inspect the level at 500-mile intervals to determine the actual rate of consumption. Be careful not to overfill the tank, as that will provide a false indication of consumption.
    • If the rate of consumption exceeds the norm, you will need to review duty cycle with the customer and then begin your inspection of the engine's state of-tune accordingly.
    4. Verify the system before you tear it down.
    • Don't overlook the obvious items before disassembly. How are the oil hoses (tight clamps, routings, etc.)?
    • Verify breather operation, this might be a carry-over situation. If you blow lightly into the breather snorkels, there should be some resistance if the umbrella
    valves are closing properly.
    • Verify oil pressure and oil return functions. You might be dealing with an oiling system issue and/or a wet-sumped lower end.
    • Take a compression reading and perform a leakdown test. Remember to write down the numbers, Technical Service is sure to ask for them.
    • If leak down exceeds 10% determine where it is leaking by. Into the lower end, out the exhaust or intake port, or through a head gasket?
    5. Now begin your disassembly based on your findings, and keep both eyes open as you take things apart for clues to the root cause.
    • If the leakage was primarily into the crankcase, then you are chasing a piston to cylinder sealing issues. To rule out a barreled or tapered cylinder re check leak down in three places (top - middle - bottom) in the stroke once the rocker arm support plate is removed.
    ƒ By the way how did those umbrellas look, and was the rocker box fairly well
    scavenged? No clogged return passages right? No signs of leakage at the head
    gasket oil returns? Good gasket surfaces?
    ƒ Check the piston crown for carbon build up. Washed areas on the edges of the piston crown are a good indication of an "oil pumper" (bad rings or piston to cylinder fit). Solid carbon build up across the piston crown generally indicated it is coming from above.
    ƒ With the cylinders off you will be able to more closely examine (and take note of) ring end gap locations. Do they match the service manual recommendations or are they lined up? Also, check the second compression ring, also called the middle or scraper ring, installation. The "dot" should face up, but even more important the outer bevel slants toward the piston and it has a slight chamfer on the ID that goes to the bottom to allow it to function properly. It is rare but sometimes the "dot" is up and ring's taper face is wrong.
    ƒ While you are looking at the rings check their wear patterns. A ring that is over spread or twisted during installation will not seal properly.
    • Leak down past the
    valves and into the ports requires you inspect them for bad seats and bent stems, or you may find carbon built up to the point they just were not able to seal the combustion chamber.
    ƒ Heavily carbon’ed
    valves and oil in the intake or exhaust ports (you did
    remember to take note of that right?) are indications of leaking valve seals.
    ƒ It also pays to look for the unusual, like leakage between the valve guide and the cylinder head. Are the guides loose? Was the head's guide bore scored or damaged during guide installation? This can sometimes be indicated by unusually clean or unusually golden patches in specific spots around the guide.
    The same is true if there is actual porosity in the head.
    August 10,
    2005
    Valve Seal Updates
    2005 models and early production 2006 vehicles use a one-piece valve seal and lower spring seat design (p/n 18094-02) that can cause oil leakage between the guide and the seal when side loaded or miss-installed. These can be identified by the silver seal ring and black rubber material.
    • A new version one-piece valve seal and lower spring seat design (p/n 18094-02A) is being implemented into service parts to improve sealing properties and minimize installation issues.
    • The first batch of this new seal can be identified by a green seal ring as shown below. Towards the end of the month 18094-02A seal kits will change to an orange colored rubber material to improve visual identification of the new parts.
    • Twin Cam 88/88B production will be moving to this design in the near future with middle-weight powertrain and service parts to follow shortly thereafter.
    • Please utilize this new design during any future top end services.
    Warranty and Service Procedures
    • Any individual 18094-02 valve seals in your inventory may be used on Middle-Weightm Powertrain repairs.
    • Current engine gasket kits may be used on 2004 - 2006 Sportster and 2003 - 2006 Buell engines.
    • Current gasket kits (top end p/n 17052-99B and engine p/n 17053-99A) may also be used on 2004 and earlier Twin Cam 88/88B engines without any special steps.
    • When using current gasket kits (top end p/n 17052-99B and engine p/n 17053-99A) on
    2005 and 2006 Twin Cam 88/88B models discard the 18094-02 valve seals included
    and use part number 18094-02A in their place, and the included seal protector during installation.
    For warranty repairs that involve the use of these engine gasket kits (p/n 17052-99B & 17053-99A), you may also claim 1 valve seal kit p/n 18094-02A as part of the repair.
    These additional parts will only be allowed on MC warranty claims filed against your existing inventory of gasket kits used to repair 2005-2006 Big Twins.
    • Future kits will have the new valve seals included so additional parts should not be listed on warranty claims.
    18094-02A Valve Seal Identification
    Hope this helps
    Carlos
  • weasel
    weasel
    Thanks for the info guys looks like have to pull it to pieces MMmm AArg
    Iwill read all of that when i have time
    Thanks again
    weaz
  • Cranky
    Cranky
    How many k's on it weasel ? I have same bike same model. no probs here as yet ?
    If they wouldn't keep blocking the stem seal research this stuff wouldn't be anywhere near as hard...
  • weasel
    weasel
    Hey Cranky
    Its got 10,300kms not many ks hey , Its annoying to have to keep topping up the oil
    I suspect its done it from new ive only had it since jan 09
    I was tryin to find out if can be done by not removing heads
    weaz
  • weasel
    weasel
    Thanks Scotty & Wozza
    Something to think about hey a bit more cubes
    And the Viton seals are supposed to be the ducks nuts
    weaz
  • jordan
    jordan
    replacing stem seals can be done without pulling the heads, 1 way is with compressed air, or a bent rod in the plug hole, but its really only an option on engines with low seat pressure, also you are so close to having the heads off anyway, it would be silly to attempt it assembled.
