EFI Management
  • bogan
    bogan
    18 years ago
    Hey there have you all seen the different sorts of EFI management modules available for harleys now?
    I have a 07 Softail and would like some input to which is the best to use, some work on throttle position and others some other way.
    Any info is appreciated, I was looking at the power commander, V&H short shots and a Arlen Ness big sucker kit.
  • GREG
    GREG
    18 years ago
    I rate the Thundermax auto. It has transformed my bike and you get the ability to fine tune without the need for a dyno.
    If you do a search using T/Max or PC you will come up with all of the discussion on them.
    Greg
