rocker covers
  • shfunky
    shfunky
    Anyone changed rocker covers on a 96ci, I want to put chrome ones on, I know it's easier with the HD low profile allen keys and also need a dogbone to help re-torque but is it worthwhile taking all the rocker gear off to get to the rocker housing plate or should I just change the covers and leave the housing plates till I have to do other maintenance that requires their removal.......Scotty ??
    Gibo
  • shfunky
    shfunky
    Thanks Scotty, the bike is a 07 Streetbob, I have a manual for the torque sequence ect but a list of gaskets and o-rings would be helpful. I can get a dogbone from work (we use them on aircraft) but am unsure what changes to the torque settings are when using it.
  • shfunky
    shfunky
    Cool, makes it easy. Just a little more info mate, do I follow the manual verbatum, like dropping the pushrod covers ect ect, the manual assumes you are doing a full top end service so are there any shortcuts and would there be any tips in your post on changing cams like the paperclip trick for the pushrod covers?
  • shfunky
    shfunky
    Thanks Scotty, much appreciated.
  • shfunky
    shfunky
    The HD parts are fn expensive, I saw a complete set of upper and lower for $179US plus $95 postage on ebay from bkrider, emailed him and he says the chrome is show quality, he sells a lot of other Harley stuff, what do you reckon?
  • shfunky
    shfunky
    Hey Scotty, pardon my ignorance mate but why would I need a  gasket for the primary and derby cover ect to do the rocker covers?
  • Deadly
    Deadly
    OK, just when I thought I had every tool known to mankind.
    WTF is a Dogbone?
    pics please, as I may have one or a full set but known by another name.
  • Deadly
    Deadly
    Thanks Scotty,
    I do have a set in metric, now I just need a real set or maybe just the 7/16
  • shfunky
    shfunky
    Hi Scotty, part number 18535-99b doesnt come up, 18535-99 comes up as an anti-rotation pin, is that what it's supposed to be?
  • shfunky
    shfunky
    Thanks mate.
  • shfunky
    shfunky
    Hey Scotty, finally got the rocker covers (upper and lower), also got the lifter covers and all gaskets, all up $500 (aus)delivered.  Going to do the job in a couple of months when the warranty expires and I finish the house extensions. I have a question for now though and was wondering if it would be a good idea to upgrade my cams while I had the covers off and the rockers off. I have intensions to do it some day and I thought maybe while I'm doing the rocker covers it would kill 2 birds with one stone.
    If so can you recommend a cam for my Streetbob that will give me a little more grunt down low to midrange. I know the topic has been done to death but I value your input mate. And would I be stretching the friendship by asking you to put a name to each of the o-rings and gaskets you listed, some are obvious and some not.
    Thanks again.
    Gibo.
  • shfunky
    shfunky
    Hey Scotty, just been going through your cam swap posts and wanted to know can I re-use my original pushrods. Also my bike has done only 20,000k's , would I need to change the cam bearings?
    I also noticed you using a paperclip to hold the lifters in place once the pushrods have been removed, but how do you do it when replacing the lifter covers?
  • shfunky
    shfunky
    Hey Scotty, just priced the cam installation and removal tools.........farrck......US$400.....plus another $34 for the cam locking tool. Would it be foolish not to change the cam bearings? Might be cheaper getting the job done by a professional, or even cheaper to fly you over here for a working holiday with your tools
  • aussiesport
    aussiesport
    anyone done the pan covers for tc96?? have seen them in a box but not on a bike yet!
