Restrictions in Header Pipes
  • Wingy
    Wingy
    Removed the mufflers and header pipes so I could remove the flapper valve and found the other pipe was  just as bad, so I also removed the balance pipe. The flapper was a prick to remove the rest was fairly easy. I used 316 s/s
    and stainless in the mig, it welded up easy...Result looks a lot cleaner and sounds f-king amazing.....BUT LOUD...
    Pics as ( if I can get it to work )   Hopefully got this in the right place, slowly getting used to this forum...
    Balance pipe restriction
    Flapper valve restriction
    Pipes off
    Flapper valve removed
    Other Pipe
    Bits I put in the bin
    Back together with S&S slashcuts
