REGO LABEL
  • dugga
    dugga
    18 years ago
    Silly question here people.  Where do you have your rego label on your bike.  The dealer put mine on the rear fender, held in by the seat screw. I dont think it looks good there but cant seem to find anywhere else to place it.  Just wondering where other people put it ?
  • blueystar
    blueystar
    18 years ago
    I KEEP MINE IN MY WALLET
  • ANDYK
    ANDYK
    18 years ago
    No rego label on bike ,papers in the pocket
  • kingchops
    kingchops
    18 years ago
    Mine's bolted on the frame at the bottom of the down tubes, good place for it as you don't really see it.
  • Mega!
    Mega!
    18 years ago
    Mines in the usual round plastic trailer type holder bolted to the rear of my rego plate with the info there for the plods to see if they pull me up.
  • dugga
    dugga
    18 years ago
    Thanks for the input fellas. Ive stuck mine in a waterproof clear plastic sleeve and then stuck it to the inside of the battery cover.
    Quick and easy to access but dosent hurt the bikes look.
  • Scorp
    Scorp
    18 years ago
    Mines in the clear disk holder but screwd to the rear of the Licence plate hidden from view but still viewable if I get stopped.
