Online: B0nes, Hilly
103 kit
  • Nibbla
    Nibbla
    I've just ordered the cam bearing tools from Georges Garage & parts from M&M for a 103" BB with 0.030" head gaskets & Andrews 54H cam swap , I will be using the standard heads for now.
    Thanks to Scotty's cam swap Im guna have a crack at it myself. My questions are......
    Do I need a S/E clutch spring?
    Do I need S/E Cylinder Studs?
    Will a 50mm throttle body give me more hp/tq, if so how much?
    Will the original lifters be ok to reuse, bike has done 17000km?
    Cheers, Nibbla
  • Nibbla
    Nibbla
    Thanks Scotty,
    What is a VPC clutch?
    I was thinking of using the SE 50mm TB (27623-05) which (I think ) comes with larger injectors fitted.
  • Surly
    Surly
    The stage 1 103 kit comes with the SE clutch spring.
    I havent noticed any slip with the clutch in mine (same set up)
    Surly
  • Surly
    Surly
    Dave,
    Yes the SE spring is in and no I haven't noticed any slip. If you have it use it.
    Surly
  • jordan
    jordan
    ya dont need to touch the clutch, ive built 103ci motors with 110hp 1000s of km old n no clutch slip, on stock heads this build wont have any more than 90hp. id put a set of se pushrods in if the cam has lots of lift (not sure on the spec of the andrews cam)
  • Nibbla
    Nibbla
    I already have the SE clutch spring so may as well fit it.
    Why would you fit pushrods if the stock ones are correct length? Are the SE pushrods stronger?
    Cheers Nibbla
