Online: beehappier, softfat
DataMaster engine data
  • Fr3d
    Fr3d
    Can anyone tell me how to get more engine data items in the main display area.  Is this information map dependant.  I have started using TQ205-002.
    When I load the sample DBW map all the items and status bit information appears.  When I load my current Vtune file I dont get O2 voltages and many other items as well as no status bit information.
    If I try to change Assign main items, the drop down list does not have the items I think should be there.  Anyone able to shed any light on this?
    Thanks
  • Fr3d
    Fr3d
    Thanks for the info lonewolf. I will check it out - as well as read the manual.
  • Doc 1
    Doc 1
    Like Scotty said, the more info the Data Master is pulling off the Buss the slower it comes so it's not as accurate.
  • Fr3d
    Fr3d
    Again thanks for the information guys.
    Previously I was reading one of Doc's comments about checking the O2 switching prior to VTune to make sure they were working correctly and decided I would try to find this information on a VTune file I had done that day without any success, but I know why now.
    This better than an Xbox
    Fr3d
  • Doc 1
    Doc 1
    There is a special data stream for 02 sensors that record just the info needed.
