Online: bikenut57, John.R
  • cattleprod
    cattleprod
    Hiya all. It's been yonks since i've been on the forum, this or anywhere (Just got a 'putor at home again). Anyways, i'm wanting to upgrade my stock bars on the '07 FXDC. For me Apes are the go, 'bout 16" i reckon. Now, i've seen complete sets pre-wired, chrome switch blocks, braided cables etc to suit for the US$570.00 mark to suit my ride. I 'spose i'm looking to hear from people with a bit more experience than i have on this topic. Pro's and cons of purchasing a "Bolt on" or; purchasing separate components. Faark, the more i read and yak to people the harder the decision seems. Any help greatly appreciated. CP
  • robert65
    robert65
    I bought my set prewired and got all the controls and brakelines (braided) with it they are top quality stuff and i have had no problems with them .
  • blueystar
    blueystar
    LOOK FOR THE ROAD SWEEPER PIC IN HERE SOME WHERE 18 INCH APES ALL OF E-BAY ALL UP LESS THAN $300 BARS BRAKE LINE CLUTCH CABLE THROTAL CABLES ECT
  • Tapey
    Tapey
    I put on 12" bars on my Duece on top of the 6" raisers and i love it. Sometimes i wish that i went a bit higher to get that better look but it may be a bit uncomfortable..?? I did it the easy way due to the fact that i didn't have much time off work and got the shop to put them on for me. All braided cables and it cost $890.00 fitted. They are just el cheapo bars as i didn't want to spend alot on bars if i did't like the outcome.
  • cattleprod
    cattleprod
    Thanks for the input fellas. A little bit of everything said rings true for me, i'm handy with a soldering iron and can read schematics ok. It's putting a cupla days together in a row that has me fecked. Can i delay the gratification long enough to wire all myself. Or, just go the easy way and get the pre-wired??!! Hmm, a little time will tell.... Decision time.
  • whiteyluvsrum
    whiteyluvsrum
    the only bad thing with solid mount riser's is you can't adjust them. you would want to try them out and make sure you are comfortable with the solids before handing over ya hard earned.
  • Cranky
    Cranky
    Solid mount risers is the only way to go if ya are a thrasher ;)
    I got 18 burleighs, Im 6ft 6 not the most comfortable but looks is more than being comfortable ;)
  • aussiesport
    aussiesport
    go z apes , there shithot had 16"z 's on me sporty awsome :)
