Online: bikenut57, John.R
Rear shock air pressure ?
  • fozz
    fozz
    Just wanting some advice on what air pressure to run in the standard rear shocks on my new 09 road  king classic. Should I go with the recommended pressures in the manual or what, do a mixture of solo and two up riding. Any  advice welcome.
    Fozz
  • phugly1
    phugly1
    have an 07 ultra, sacked the air shocks, got sick of always checking air. Bought a pair of ikons and am very impressed. No wallowing in corners. When I go over bumpy surface it doesn't ride like a tinny bobbing in the water! Mostly 2 up me 120kg the 'significant' other 80kg. She claims the difference is very noticable, not constantly moving bum around after hitting a bump!
  • twincam88b
    twincam88b
    Fozz I have the 08 RKC and when I bought it it had Zero pressure, that's what they are set at from the factory apparantly. I bought the Harley pump, which is a low volume pump. I ride mainly 2 up and have mine set at 25psi as worked out from the manual, eg weight and load. I don't worry about dropping pressure when I'm solo. If I'm going on a big ride 2 up I check it before I leave. I think the later models have different pressures from the earlier models, different shocky sizes I take it.
  • Hoodaman
    Hoodaman
    same story with mine TC.........
  • aussiesport
    aussiesport
    mate have i got a story for you !!!!! lol i set mine at 10-12 psi solo im 105kg and 2 up no gear 35-45 psi were big people rofl and 2 up loaded to the max 50 psi maximum ! hope that helps a bit :) dont ever go over 50 psi tho ......
  • fozz
    fozz
    thanks to all who gave advice, much appreciated
    Fozz
  • Fr3d
    Fr3d
    I was a bit sick of losing pressure all the time, the sagging under brakes, the very ordinary ride so did a Phugly and put a set of real shocks on. Ones with good springs and controlable damping. Works for me now. Oh the front dampers were fixed as well.
    Just loves Mac pass.
  • gjp2002
    gjp2002
    From the workshop manual
    Do not exceed recommended air pressure, air components will fail rapidly.
    FLHR/C, FLHT/C/U & FLTR  - max pressure 35psi
    FLHX - max pressure 50psi
    Yep, point taken. This is for 2008 model.
  • aussiesport
    aussiesport
    doh! sorry scotty i was refering to my scoota which is a 09 ultra ,.i just assumed fozz's 09 rkc would be the same :(
  • PigironBob
    PigironBob
    Just goes to show you, YA GOTTA RTFM..                                      Read The Farking Manual
  • aussiesport
    aussiesport
    hang on i said that 50 psi was max ?!?!?!? hrmm go figure , but levels are taken from book? for 09 ultra , and the other levels are just what i like to run personaly ? maybe your reffering to someone else not me ? i dunno to hard to keep track of what ...
  • aussiesport
    aussiesport
    doh ! i am going thru menapuase :( far%me ....rofl
