Online: harderomaleuses
Air filter cleaning?
  • Tapey
    Tapey
    I am taking my air filter off to give it a clean, and in the past have just given it a fuel wash, but was talking to a mate and he said that you are ment to soak them in oil afterwards. Is this true? Its a K&N filter out of a Hypercharger.
  • Chips
    Chips
    K&N filter oik takes all the crap out of the air that the filter itself will tend to let through. If you follow the instructions on the can, you will never have a problem with a K&N filter. Especially here in the Red Centre where everything dries out and we've got lots of really fine dust (bulldust)
  • PigironBob
    PigironBob
    If it's a K&N yes that is correct.  You should go and purchase a proper K&N service kit, it contains the cleaning fluid and the correct oil to use. The kit is well worth the $ and will give you many services. 1 thing to remeber is K&N filters should only be serviced at recommened intervals, this is usually about 100,000kms, they many need some reoiling if they get water on them and start to dry out.  I would never, never wash a K&N in petrol as this is not good for them.
    Just my 00.02 cents worth.
    Bob
  • Tapey
    Tapey
    Thanks for the info.
  • Tapey
    Tapey
    Got the filter oil and gave it a good clean. The oil should last me ages as i was told you only spray on a little bit. Know i know what to do for future reference...thanks.
  • MapleLeafs
    MapleLeafs
    There's a good video on expert village for cleaning a K&N filter, by Jerry Fishel. He uses the K&N kit to oil it up.
    http://www.expertvillage.com/video/18219_motorcycle-air-filter.htm
  • Tapey
    Tapey
    Ratsmo, i went to the local Harley shop to get the oil for the filter and they said to blow the air filter with an aircompresser first across the fins gently to get rid of all the dirt first...and a heap of shit came out.
  • mooky160
    mooky160
    While we are on the subject, what is the best way to clean a HD heavy breather filter?
