Online: harderomaleuses
03 s/tail gearbox
  • robert65
    robert65
    my mate has a 03 softail gearbox and is experiencing a rattling noise when he ischanging through the gears we dropped the oil and found some metal shavings on the plug the bike has done about 80,000klms. any one got an idea on problems that could be happening ?
  • robcig
    robcig
    Some fine metal on the plug is normal. Chunks of metal are not. Was there any change since you replaced the oil?
  • robcig
    robcig
    I'd recommend the same. Good stuff that Redline!!
