Can I use VE's from previous dyno
  • Fr3d
    Fr3d
    Scotty/Doc
    My current build on my 08FLHRC has been dynoed with a SERT and is set to run in open loop, i.e. the AFR have all been set below 14.6.  It runs well but give it a fist full and it uses a lot of fuel.
    I have selected my TTS map and will be doing V-Tune soon but was curious to know if I can copy accross the VE's already worked out on the dyno for this build into my first run map to help speed things up but also to get WOT values?
    Is this a good or bad idea?
    Thanks
  • Steve Cole
    Steve Cole
    Half the fun is trying things to see how it works out. Use your head and be careful and you can try most anything without issues and then you learn. I find most of my many mistakes always teach me more than if it works right off the bat!
  • vtwinbmx
    vtwinbmx
    Steve shouldn't the Ve's be close in his bike. He isn't changing anything other then making an AFR change
  • Steve Cole
    Steve Cole
    Since I have no idea of how good or bad the previous dyno tune was done it's hard to answer. As others have stated doing a few Vtune runs and it will be corrected anyways so its up to him what he want to try.
