Master cylinder lids corroding 07 softail
  • Tengy
    Tengy
    A mate has an 07 softail custom and has both of the brake fluid cylinders with corrosion around the top. They have never been removed. Warranty ran out a few months ago. Stealer took photos to look into replaceing under warranty, will see what happens.
    Dot 4 fluid being used in HD, when did they stop using Dot 5 ??
    Anyone else got the same problem ???
    Check them out before warranty runs out
  • Hoodaman
    Hoodaman
    yup ive had 2 replaced (warrenty) and now the rear is doing it as well...........mine is an 08 FLHRC and it just keeps happening..........sux rea;;y........
  • twincam88b
    twincam88b
    Just been out to the shed, same bike as Hoodaman, and mine look like new still. Does say DOT4 on the lids.
  • Magilla
    Magilla
    My front master cylinder started leaking a month after I got the bike and stuffed all the paint around the lid. Steeler reckons they overfill the cylinder at the factory and when it heats up the oil expands and the leaks happen. They replaced the lid. Well guess what? Its leaking yet again and eating the paint away once more. Wonder what the next excuse will be? Mine a 08 Fatty
  • lucky
    lucky
    i was cleaning the bike yesterday , [ 07 heritage ] and noticed weeping around the master cylinder , no paint loss yet !!!  thanks for the tip , i'll get on it asap.
  • Tengy
    Tengy
    A bit bubbly means you will get more until the paint flakes off.
    There should be no bubbles of paint at all.
    Look into warranty and get new seals and cap.
  • Bli Bli Bandit
    Bli Bli Bandit
    my fat bob is doing it, the dealer said they have ordered a new one.
