Online: Merv
Tired fork springs 94 sporty
  • ratz
    ratz
    Have just been for a fang on the old 94 sporty after doing a 883>1200 conversion, it made 40 K,s without me ute so i am very hapee. Now im not a complete fat bastard and am noticing that the forks in these old gals aint wot they used to be or from some reading i have done they never were!! Any particular way to go for beefing them up abit without getting a loan, like goin to the bike wreckers and poaching sumfin out of a rice grinder?? Any suggestions plse
    Ratz shiny side up
    new oil and a 3/4 shim under the spring will fix it
  • ratz
    ratz
    Yea thanks folks, i will prob go with the shim and thicker oil combo untill i get the progressive springs, the shim i take it, is a bit of thick wall pvc tube and place it on top of the springs and then screw the caps on yea??? I put 2" overs on the Fatty and and put the same style spacer/shim (2") in to compensate for the xtension.
  • sportytrace
    sportytrace
    Rather than thicker oil, which will just make your forks really slow to react to bumps, try adding more 10w or 15w oil to each fork leg if you are trying to prevent bottoming out. That with more preload should help you out.
  • sportytrace
    sportytrace
    Another thought....
    A reasonably cheap solution for fork springs that are too weak (or worn out) is to add air valves to your fork caps. Drill and tap a threaded hole in the fork caps and screw in a schrader valve fitting. 5 or 6 lbs of air pressure (or less) is all that's needed.
  • ratz
    ratz
    Thanks sporty Trace i hear ya i know that the thiker oil has a better dampening attitude but takes forever to come bak up again which can be anuther prob, il do a tube clean an then nu oil an a shim/spacer then sell 1 of the bairns for some Cerinai hardware if i can get its ticker running proper, cheers the Rat
  • ratz
    ratz
    Yea well it kudnt be much old mate shud be measured in pies and stubbies i reckon, are they weeping??? and if they are then its worth alot to you. Rats
  • ratz
    ratz
    walka howdy, been away for a while on this subject, the 3/4" (19ml) shim i take it just made out of conduit an placed down under the fork springs or on top or source some progressive springs yea??? cheers ratz
