New TTS manual
  • Fr3d
    Fr3d
    Scotty, I hope you can help?
    The new manual ask to: select the new MT7 file, set the AFR to 14.6, adjust the CLB voltages, diable the PE, set the tuning constants then save the file and program into the ECM.  No problem.
    However other previous documents I have read ask to also; se Acel to 0, set Decel to 0, set warm up enrichment to 0, set adaptive knock retard to 0 and disable knock before I save and program into the ECM.
    Is this required, or something that is a good idea to do?  Any comments appreciated.  Thanks.
  • PigironBob
    PigironBob
    AFV? used to mean Armoured Fighting Vehicle to me in a past life but dunno what it means in relation to TTS tuning.
  • PigironBob
    PigironBob
    Thanks Scotty, knew you would know about AFV ...................
  • Fr3d
    Fr3d
    Thanks for clearing this up Scotty.
    Will follow you instructions.
  • Rooster
    Rooster
    Thanks PB for asking the question and to Scotty for the answer.
    I have been meaning to ask this one myself for a while.
