Online:
Merv
Brake Fitment
Brake Fitment
Brett
Hilly . Fatbobs ain't fitted with brembo's worse luck ! unless the new cvo's are ? But the brembo caliper from a V-rod or the non ABS baggers should bolt on . you will need a 300mm ? rotor though as standard dyna rotors are 290mm ?
