heel toe shifter won't "spring" back
  • FLSTC
    FLSTC
    18 years ago
    the gear change does work but only after getting the shifter back to where it should sit after changing up or down. cannot see a spring along the linkage - before i get the tools out can anybody advise whether there is a spring (somewhere ?) .  the trusty can of wd40 didn't work - which means there is definitely a problem!   ........ and just before the long weekend !!!!  tia
  • FLSTC
    FLSTC
    18 years ago
    thanks wayne- about to start the job now . let you know the result.
  • FLSTC
    FLSTC
    18 years ago
    Wayne , you are on the money. my weekend just brightened up . cheers
  • FLSTC
    FLSTC
    18 years ago
    job done - thanks Wayne
