Online: beaglebasher, tussuck, Hilly
CHECK YOUR NUTS BOYS, CHECK YOUR NUTS
    I was riding it to work this Morning and felt a bit of a Wobble, so I pulled over to have a look and found that my Rear Axle was Loose,  I was lucky there was a Panel shop nearby where I tigthened it up. When I get home tonight I will give it a licking of Loctite.    SO CHECK YOUR NUTS
  • robert65
    robert65
    harley davidson and loctite go together. I luv the stuff.
  • weasel
    weasel
    Walka
    fuck i thought this thread was about testicals
    weaz
  • lucky
    lucky
    good point , too late once theyv'e fallen off !!!  tighten the nuts on my ikea funiture often
  • MapleLeafs
    MapleLeafs
    No lumps on my bike and checked my axles and pushrod in the bathroom - seem fine too...
    Hmmmm...
    Good advice though Walka. I am down to once per fortnight doing a righty-tighty on all the parts. Found three of my footpegs could be turned by hand so re-torqued. Seaeagle lost a shifter peg on a run the other week...
  • AJ56
    AJ56
    out of curiosity can you put new loctite on old?  If you know what I mean.  I went out and my axle has a retaining pin through the nut
  • Cranky
    Cranky
    The old Cotter pins used to work a treat
    gave mine a good going over last month.... used ultrasound
  • twincam88b
    twincam88b
    Good tip Walka
  • matt08
    matt08
    my mrs normally checks mine
