no licence
  • WhatTaxi
    WhatTaxi
    Well not me but a m8 just lost his for 3 month's  , he has a 08 softail standard  he asked me should he take the battery out or get a trickle charger for the whole 3 months or just use it every two weeks or so ?  i dont know ......whats the best thing to do ????
    Thanks guys
  • Fangio
    Fangio
    keep riding it
  • rowie
    rowie
    If you are a good mate Taxi he'll let you ride it to keep it charged. If not, there are trickle chargers you can get (got one fitted for $75 by the stealer at the last service) that they use in the states during the "off" season. Supposedly dont cause any harm to be left on 24/7.
    Problem with Fangios advice is that at the present you are probably more likely to be pulled up by the constabulary, no licence means deeper crap.
  • Tengy
    Tengy
    There are maintenance chargers that are smarted tha the average battery charger. C-Tec do a good job and 800 milliamp will do the job. Battery worl install and are just under $100.
    3 months is not that long but get caught and do another 6 and it starts to add up.
    Good luck
  • lucky
    lucky
    definately don't ride !!!  too much heat on at the moment . trickle charger's good , worth the investment , nice to know you can fire up whenever it takes your fancy no matter how long between rides !!!
  • WhatTaxi
    WhatTaxi
    Thank's guys for all ya info , i'll pass it on 2 him
    Taxi
  • OSP1340
    OSP1340
    When I left the states back in Sept last year my bike was not pluged in.
    I was a little worried about the battery when it got here but it fired right up and that was 7 months just sitting there.
