Tyres
  • nobody
    nobody
    Ok thought I might try and start a bit of banter.
    What brand of tyres are people out here useing on their Harleys
    Interesting to compare to what they like in the U.S.
    nobody
  • boofhead
    boofhead
    Hi Nobody
    Right now I'm rinning an Avon. Not a bad tyre at all but have been konwn to blow sidewalls at low pressure !
    Cheers Boof
  • nobody
    nobody
    Ok looks like noone is going to say much about tyres,so I guess I will start the ball rolling myself
    For the last few years I have been useing Avon Venoms exclusively and have found them to be excellent in the wet and dry.
    Currently I have the Standard Dunglops.... and they are just that crap........... they came on the new bike.Just waiting for them to wear out and then I will get my 18" wheels and put some Avons on .
    I notice that on the U.S. site Metzler seems to be all the rage,be interested to hear other experiences here.
    nobody
  • sophtayl
    sophtayl
    Hi All,
    I concur with most on here.....The stock front is crap!. I have recently changed to the venom. Much better and looks fuller in the guard also.
    I quite like the back tyre. I think I will be replacing it with the same as original.
    Mick
  • kensim
    kensim
    i went to get a new tyre 160/70/17 ,avon tyre is a radial not cross ply,should last longer i hope.original only 6000 k.
  • stbobrhino
    stbobrhino
    I got 1000ks out of the stock rear and have run an 880 Metz for the next 7000 so far. the stock Dunny filled the guard better and the dealer's not keen to put a 170 on in the Metz but it's been good so far.. I've got 17000 out of the stock front and it will be replaced with the 880 as well... like others, I felt like the front slipped about a bit in the wet....
  • kingchops
    kingchops
    Only 1000k's on the stock rear, that doesn't sound like much I've done more than that on the stock tyre and it still looks fine. What type of roads do you ride on?
  • BACAMICK
    BACAMICK
    i run a contiforce 180 * 17 on the stock 4.5" rim 07 bob, works great
  • stbobrhino
    stbobrhino
    Kingchops........   every road between port fairy on the south coast and batemans bay on the east coast.......  I thought I did alright....  a mate with a lowrider changed his rear at about 9000....   and we did nearly all those k's together...
  • nobody
    nobody
    I think there might have been a misprint earlier as your earlier post says 1000k's and I think it should have read 10,000km's if you got better than your mate got 9,000km's...............don't ya just love typos
    nobody
  • kingchops
    kingchops
    I rekon you got it nobody.
    Man, that is one fantastic shot, it doesn't get better than that!
  • stbobrhino
    stbobrhino
    Yep, my *&%$ up sorry fellas, 10,000 would be correct
  • boofhead
    boofhead
    Only 2500 Kms ? Holy crap
    I've had my stock front on for 17,000 km (it's in pretty bad shape now though, I'm about to replace).
    Rear wore out at about 10,000
  • nobody
    nobody
    My Dunlops are still like new,but I have been offered some ME880's at a really good price,so I think I will grab them and give them a go,usually an Avon user,but for the price I can get the Metzlers at I can't pass them up
    nobody
  • AUSFXD
    AUSFXD
    ME880's once the stock Dunlops were worn out. IMHO they are a much better tyre. Nice and stable in the first lot of rain we've had in a while in Darwin today.
    Hi Guys and Girls.
    I am up for a new front tyre on my Super Glide I have been running the ME88 Metzelers which i reckon are a great tyre.
    My Question is has anyone used the Continentals brand and if so what do you think of them.
    Any feedback would be great.
    cheers sparkie
  • czarek
    czarek
    Guys, johno asked how much are you paying for 880Metz. I would like to know too as I am due for replacement very soon.
    Cheers, any answer appreciated.
  • nobody
    nobody
    I did read on the U.S. forum,and I had a look on the continental site as well,that Continental don't list a tyre for the larger Harleys as they are not rated to carry the load.
    nobody
    nobody
    Thats very interesting because the local bike tyre shop said he could
    fit one for me for $149.00.
    I'll have to look into it some more.
    Thanks for the info.
    czarek/johno
    Re the metz 880 I paid $210.00 for the rear 140/90-16
    and $159.00 for the front 100/90-19.
    Hope that helps
    cheers sparkie
  • Mainey88
    Mainey88
    Off topic a bit but if I replace the standard banglop rear tyre from 06 FXDLI with a metz can I upgrade from a 160 to say a 170 or 180 without any hassels to fill the guard out a bit. I understand the metz's are a bit skinnier than standard (correct me if i'm wrong), dont want to loose the wide look. Would I need spacers etc or is it just fit her up and ride. I'm not sure waht you get in a wide tyre kit from the stealer.
    Was going to post in workshop but seeing as we are on the subject
