Hi Flow Air Filter
  • dugga
    dugga
    18 years ago
    OK IVE READ OTHER THREADS ABOUT high flow FILTERS AND REMAPPING THE ECU ( FACTORY OR AFTERMARKET). ALSO LOOKED ON OTHER WEBSITES AND THERE SEEMS TO BE A LOT OF CONFUSION ABOUT THE NEED TO REMAP OR ADD A FUELPAK ETC.  iVE ALREADY GOT SOME S&S PIPES ON THE 07 883C AND AND NOW LOOKING TOWARDS THE AIRFILTER.  DO I OR DONT I NEED TO GET THE ECU ADJ? AND HOW MUCH DOES THE ACTUAL SCREAMING EAGLE FILTER COST ?  IVE READ SOME SCARY POSTS ABOUT THE COST OF REMAPPING THE ECU.
  • kingchops
    kingchops
    18 years ago
    Dugga,
    My experience was that when you have both pipes and high flow air filter you need a fuel manager.  When I first got my bike I initially got Screamin Eagle pipes, there was no need for a fuel manager but when I put the SE Air Filter on the bike didn't run good.  I took the air filter off until I could get a V&H fuelpak.  When I installed the air filter with the appropriate fuelpak settings the bike ran great.  So if you ask me you definately need a fuel manager if you go both high flow pipes and air filter.
    I bought the Screamin Eagle direct from the US and I think the cost was around $200 AUD.
  • dugga
    dugga
    18 years ago
    THANKS FOR THE INPUT KINGCHOPS. I MIGHT HAVE TO GO WITH THE FUELPAK OPTION. JUST A QUICK NOTE
    WHAT IS THE SE AIR FILTER LIKE TO FIT. IM FAIRLY MECHANICAL MINDED BUT DONT HAVE AN ENGINE BACKGROUND.
  • bretho
    bretho
    18 years ago
    07 883 c slip on mufflers and air cleaner kit was no problem on mine and also my brothers without fu@$ing around with any of the fuel system.
    Take my advice and dont use a fuel tuner, they dont modify the air fuel ratio they only add or decrease the amount of fuel going into your cylinders,
    Just my 2 bobs worth, but hey if you want to throw $500 away go for it, cheers Bretho
