Spoked wheels for 07 dyna's
  • black29d
    black29d
    18 years ago
    I am looking to put on my 07 superglide spoked wheels instead of those die cast mag wheels
    what I want to know is can wheel hubs from 2000 up be fitted if I change the wheel bearings to suit the 1 inch axle instead of 3/4 inch
    I have just won a 2004 front hub on ebay, I already have a rim set hanging in the roof of the shed, just need to find a rear hub
    Peter
  • BACAMICK
    BACAMICK
    18 years ago
    ive just change a 07 fat boy rim , from 3/4 to street bob 1" bearings, it looks like there all
    (52mm) OD and a 21mm width , bigest proble i found that ya cant get them from places like CBC etc , the ones they have are , think it was 16mm wide, so i went HD, they also can order the squash tube
