Online: beaglebasher, tussuck, Hilly
Armorall tyre shine
  • Tapey
    Tapey
    I use tyre shine on my black engine to keep it looking good, which i found about on the forum, i told a mate and he went and got Armorall tyre shine. I use the stuff in the spray can which is tops. Is the Armorall stuff ok to use on the engine as well or not? I dont want to stuff up his bike. Thanks.
  • jacks
    jacks
    Never thought of that.........I've been using black nugget.....
  • coz
    coz
    Armour all contains silicon--silicon creats static --dust sticks to static.
    If you like a brown bike ---------?
  • Wingy
    Wingy
    I use INOX on the motor, mags and plain MR SHEEN on the shiny bits inc chrome ..........
  • Cranky
    Cranky
    Yup, Silicone spray all the way, also good for tight zippers on Caravan annexes I found out by being lazy one day lol
    Brings the black up on ya engine better than new, I have also heard of people who recommended Mr Sheen as Tapey said
  • Magilla
    Magilla
    Armourall is latin for dust magnet and Greek for cooking oil
  • shfunky
    shfunky
    I have some white Maguiar's metal polish stains on the black fins next to the rocker covers from trying to polish out the stains on the rocker covers left by Trivetts after washing my bike when it was hot, anyone have a idea for removing these stains, I have tried several things without success, can you use a pressure cleaner on the fins without damaging the black parts?
  • Chips
    Chips
    I used to clean my whitewalls with a scouring pad and never, never used any kind of lubricant on the sides of tyres. If ya want them clean, hit em with some elbow grease and a scouring pad.
    I like my silver engine....
