Online: John.R, Hilly
valve stem caps .
  • lucky
    lucky
    has anybody had this problem ??? sundays ride stuffed because of a flat tyre ,jacks came over monday , pumped the tyre up , we checked the tyre , no nail. no splits . no obvious leaks , the tyre stayed up !!! finally figured it out , i had bought a set of skull valve stem caps , the thread was short , so when they were tightened opened the valve , bingo !!! flat tyre , took them off , no problem since .
  • Hoodaman
    Hoodaman
    shit hey...........i was only today looking for something like that.........ill be a little more careful with em if i get em........
    so u needed to piss em orf or just not do up all the way????????????
  • Mainey88
    Mainey88
    not a fan of anything like these, the heavier ones can also throw your wheel balance out ..........
  • Hoodaman
    Hoodaman
    thanx mate....off the list now
  • Hootin
    Hootin
    I was looking at getting a couple of those caps, maybe i'll do what I did with my purple dragster in 1973, put  some spit on the valve and look for the bubbles.....memories...
  • JD
    JD
    mine have been ok
  • Tengy
    Tengy
    I got a set of chrome caps from my local tyre shop, they cover the whole thread on the stem and have a rubber ring at the top to seal if the valve leaks. That are smooth with a little knurling at teh top and look pretty good.
  • Soapbox2627
    Soapbox2627
    Why not get the skulls and an old valve stem minus the valve, screw them together to protect the thread, stick them in the vice (stems), put a drill up the middle and drill out the sculls a bit to give clearance to the valve thingy.
    saves you throwing them out
