Online: John.R, Hilly
Tubeless Tyre fixerupers
  • weasel
    weasel
    Anybody know of any good/bad motorcycle tyre fixers  in sth eastern sub
    As i have just found slow leak on rear tyre,goes from 35psi to 15psi overnight
    Its a solid wheel from fat boy, not sure were is leak but not comin from valve fuckin
    Its a good job i noticed this while on the roll the dice run after just been doin fastness
    I will await your responses with bated breath an flat tyre
    Many Thanks
    weaz
  • weasel
    weasel
    OH i almost forgot i dont want to use the H/D dealers cause i dont like the mothers
    Iam goin to ripp the wheel out tonite
    Weaz
  • Jake
    Jake
    try tyrepower just a thought..........
  • weasel
    weasel
    Hey Jake
    I will do the ring around tomorrow
    weaz
  • lucky
    lucky
    gidday weasel, jacks swears by pablo's , factory 2 / 16 rosemary crt. mulgrave . 95615522.   cheers lucky .
  • weasel
    weasel
    Thanks for the leads guys but have spoken to my fav stealer
    An guess what they have dunlop 401 for 200 clams
    So gona donate 200 sovs an get one,
    As iam not big on fixing tubeless as they want $30 to do that
    weaz
    Edit :  Ah ye i almost forgot it had a nail in it that what was causin the leak bastid
  • weasel
    weasel
    I ended up buyin the dunlop 401 from P/stevens in dandenong
    for $200+$7 for fitting an it is all good
    Have a good easter
    weaz
