Online: Soapbox2627, Hilly
blowing oil from breather on 69 ironhead
  • Bourkie
    Bourkie
    HI Guys,
    just fixed the valve guide problems that caused my 69 ironhead sportster to smoke, started it up it runs very nicely then I noticed the breather off the generator drive casing is blowing heaps of oil. could this be the check ball valve on the oil pump stuck open and allowing oil to drain back into the crank case when sitting then being blown out at startup???
    Cheers,
    Peter
  • Bourkie
    Bourkie
    thanks scotty, iwill clean the check valve and get some 60 weight oil
