G'day, just wondering what you guys are using for detailing the crome work? I brought a HD microfibre cloth but find it hard to polish with and leaves little fibres, I brought a bag of rags and it seems easier to polish with.
gidday jason . pack of three microfibre cloths from safeways , for a quick clean , mr sheen is good , but for a good detail jacks put me onto purple polish , great stuff !!! good luck mate .
yep, mr sheen for me too....
I use Wicked. Wipe it on with one of the kids old socks and wipe it off and bingo, all shiny again.
A truck driver put me onto it cause thats all he uses and it is the best stuff I have used to date.
I've been advised by a Panel Beater mate to use "Windex" or simular very sparingly because of the Amonia Content (overspray onto paintwork will remove polish)
For me McGuires does the trick....
