Preloads!!
  • MapleLeafs
    MapleLeafs
    Just looking for some word of mouth advice on setting preloads.  In this case, an XL 1200 custom - but for any Sporties in general.  [Rear shocks].
    Mine currently sits at #1 or the minimum - from the factory.  Its fine for the most part, but there's a couple of places I am known to have some bottoming out, especially on the Monash Rumblestrip aka Freeway.
    I was gonna go tweak it up maybe a notch, checking the sag as well.  Thoughts?  That too and I should get used to fiddling about cos I may have some female bling on the back every so often too.
    I have one of those open spanner things for for adjustment.  How hard do you need to give it a twist to make the adjustment - just using the wrist n elbow or should you use some hits with a hammer?
  • Phillthy
    Phillthy
    You will have to change them out to get a better ride.
    I had mine on 3 the highest setting and would bottom out and I'm 90kg.
    I went with Ikon shocks and love them.
  • MapleLeafs
    MapleLeafs
    Excellent, thanks for the posts lads. I might give it a go, even if just for experiment's sake to begin with.
    I just heard about the hammer thing from some Jap/dirt bike forums - though on reflection these would be bikes where the shock is hard to reach with just the spanner and its a workaround.
    You guys are champs, appreciated.
  • Sprocket
    Sprocket
    I only weigh around 70 kilos and I had been riding the bike for a year on #1 setting. On my way to work it would regularly bottom out at certain locations. A month ago I bought a $20 shock spanner from the dealer. I tried a few settings and soon decided on #3 position. I was amazed at the difference it made.
    I wish I had tried adjusting it a year ago.
    S
  • MapleLeafs
    MapleLeafs
    I'm up to two, but after riding the road from Koo Wee Rup to Bayles, I wish it was on five. That thing is a horse track!
  • nimo07sporty
    nimo07sporty
    well just my two cents but i have an 07 custom, by myself i use # 3 and with the gf i have it on # 5 and its not bad still bit rough but i just going to get me some new shockies as the standard HD ones are just not mucu chop hey just play with it and youll see hey
  • mycustom47
    mycustom47
    Thanks Grumpy been giving dealer shit about ride on new 883 custom gone to position 4 better, still not great it's hard to tell when front forks are shit as well
