Online: snoozy
O2 Reading
  • Banditvox
    Banditvox
    I disconnected my front o2 sensor and connected an NGK FX mixer reader to the front exahust and at idle the reading was 13.9-14.2 the bike was warmed up 20 minute ride. The bikes front o2 sensor was disconnected will this give a false reading? Or do i need to stick the NGK sensor up the exhaust pipe past the muffler? I have a set of pipes on the bike but not sure what brand they are these were on the bike when i got it. Air filter stock. Do i need to get a TTS Master Tune or thundermax?
  • Banditvox
    Banditvox
    Scotty i did turn off the bike to get the bike sensor out it was hot as expected. then i put the ngk one in i ran it at idle for about 2 minutes. So what should then reading be? When i get the TTS should it be about 13.0 at idle?
  • Banditvox
    Banditvox
    Wheres the best place to get a screamin eagle air cleaner kit?
  • Banditvox
    Banditvox
    Cheers Scotty I just ordered the TTS from John he can also get the screamin eagle air kits a cheaper rate. About a week should be here or may be just after Easter. Hopefully the TTS system is not to hard to use.
  • Rooster
    Rooster
    Bandit,
    How much did you end up paying for the TTS in Aussie dollars after the exchange rate.
    I am going to get one from John for my sporty also, but was waiting for the AUD to rise better than "peso" status.
    Also, I would be interested in what an SE air cleaner goes for. PM if you feel the need.
    Cheers......... Rooster
  • Banditvox
    Banditvox
    Rooster the SE air cleaner is $139.00 US and the TTS from John was $379.00 usb cable $69.00 freight $26 with the exchage rate today it cost $875.00 oz dollars.
  • Rooster
    Rooster
    If that is for the whole lot ;  ie. TTS, usb cable, air cleaner and freight,
    then $875 sounds pretty good to me. I think I might contact john again.
    Thanks bandit
  • Banditvox
    Banditvox
    Rooster that was for the whole lot the dollar droped a little today so may reach .70 cents by Friday.
