Online: John.R
new pics of my 04 1200c
  • coops
    coops
    just thought I'd share some pic's of my sporty
    My binoculars are in the shop getting fixed so perhaps bigger pics would be better?
  • coops
    coops
    sorry bonkers
    still trying to work out photobuket, I think I've worked it now
    Nice Pipes!!!!!!
  • coops
    coops
    Thanks Walka I thought you might.
    I'm real happy with them they've changed the whole look of the bike,
    looking forward to catching up on the weekend to meet a few of the boy's
  • coops
    coops
    thanks lofty
    Interesting, they are the bars, seat (well close) and pipes I wanted for my Sporty. If it was all black I'd think you were invading my mind...
  • coops
    coops
    hey bonkers I'm not that good at mind reading but my wife thinks she pretty good at it
  • con7502003
    con7502003
    bike looks good ive got same model cheers greg
  • coops
    coops
    got any pic's con ?
  • con7502003
    con7502003
    yeah got some pics how do you put them on here
    Here you go... how to get photos into the forum via photobucket in 10 easy steps. I put this together for my Dad... and if he can follow them successfully it can't be too hard
    1. Go to http://www.photobucket.com Click the join now tab.
    2. Fill in your details and sign up.
    3. When you get to the “my album” page Click on the Browse button. Select the location of the photo you want to upload from your harddrive. Then click upload.
    4. Be patient while the image is uploaded. You will then get a message saying "1 of 1 image has been uploaded".
    5. Scroll down to the image and click on it. The image will appear in a large format. Along the top of the image will be some links.
    6. Click on "Rotate" if you need to change the image's orientation.
    7. If your image is already up the right way up then click on "Resize" and from the pull-down menu and select "message board 640x480" then "ok" in the pop up window. (If this option isn't in the pull-down menu then your image is already a good size and you can go to the next step!)
    8. Then on the right-hand side of the image you will see some text boxes. Go to the bottom text box that says "IMG code - Forums and Bulletin Boards", Click your cursor inside that text box and you will see a little yellow box appear that says "copied". That code is now copied onto your computer's clipboard.
    9. Come back here to the forum and in the message you've been typing, click so that your cursor is where you want the image to appear. Then right-click on your mouse and select paste. The code should now appear in your message.
    10. When you click on submit that code will become an image within the message. If you are using the "post reply" function then you can click on "preview" and see what your message will look like with the image in it before you hit submit.
    GOOD LUCK!
    HDFADMIN EDIT: See this link about a shortcut to accessing Photobucket on the site: http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=14&postid=78632&view=topic
  • coops
    coops
    hey skull their a 6' rise and 2' pull back I think they are venturi bars paid about  $150 @ ps
  • coops
    coops
    I got mine @ peter stevens but I had a look on good old ebay and found a set for $100 free post. Search "t bars" and it was the second or third listing
  • grafpak
    grafpak
    i've got 10" burliegh t-bars (very nice)but was just looking on there site and new bars are over $500-00 !!!!!!!!!!!!!!!!!!
  • grafpak
    grafpak
    ps...looking good !!!!!!!!!!!!!!!!
  • MapleLeafs
    MapleLeafs
    Nice to meet you today, Coops. Hopefull there's more rides and cheap laughs to come real soon!
    PS - will post a pic of my Sportster in Walka's sporty pic thread, when I get a killer daytime pic (the shed one where the chrome don't show up ain't so good, farkin).
  • con7502003
    con7502003
    hey coops just wondering wot size stock jets yours had in it .and wot size jets you got now cheers greg warrnambool.
  • coops
    coops
    hey con I'd have to say I like your taste in bikes as for the jet size it the origonal size I just can't find out what size it is though, I had a look in the manual and can't find it
