Online: WideglidingNZ
security alarm
  • matt08
    matt08
    stop losing your fobs that should do the trick  i mean its an 09 and youve lost both
  • Tengy
    Tengy
    I was thinking the Prince Albert might B good, that way you only have to take a step back when you notice it missing.
  • gtsr
    gtsr
    i had lost my fob too- went in to dealer to get new fob went home did what the owners manual said and all worked fine- easy pleasyreprogramed it
  • lucky
    lucky
    just buy a new harley every two years ,you'll always be under warranty !!!!!  no!!!! i can't afford it  , might be a good idea though !!!    ha ha .
  • Tengy
    Tengy
    Brianstrap
    Thanks man, Is a good heads up so we don't make the same mistake. Only thing I am woried about that the spare goes flat when I want to use it. I have found that every 2 years is a good time to change batteries so you don't end up stuck somewhere trying to remember how to bypass the FOB.
    I will go and get the battery checked tomrrow and see how it is.
