Online: Soapbox2627, Far Canal
Handle bar help required
  • BAKES
    BAKES
    G'day all
    hopefully some one can help me.
    I have a 2008 1200 custom Sporty, and I want to put on, what I think you call half ape handle bars.
    Can you put these on my scoot and if so what is the part number and what else needs to be changed, brakelines, cables etc.
    Thanks in advance
    BAKES
  • sophtayl
    sophtayl
    Hi Bakes,
    10" mini apes I think is what you are referring to.
    THere are some posts here with the info you need. RKC07 posted some a while back.
    Do a search and you'll get the info you need.
    Mick
  • BAKES
    BAKES
    Cheers Mick
    searching now
    BAKES
  • jacks
    jacks
    Should look good Bakes, with luck cables etc should fit,,,,,cross fingers.....
  • Ferret
    Ferret
    G'day Bakes,
    I'm after a set a mini apes also. HD have the factory bars, which are the same as on the street bob, I'm pretty sure, which have a 12 inch rise.
    I was initially looking at these but came across the Roland Sands Design 12 inch mini apes. Cost wise they are shitloads more than the HD bars (like 500+ compared to 150) but they look shit hot.
    I'll more than likley have to order these from the US cause I still haven't found anywhere who stocks RSD parts in Oz.
