Online: Humbug, beaglebasher
shovel lifter help....
  • seaeagle
    seaeagle
    im under the impression i have hyd. lifters... i could lift one straight out of the roller/block housing. the other 3 were very tight, what are they supposed to be?loose or tight?
    the adujusting part is on the lifter not the push rod... its a 77 shovel.
    i have the manual but its got the adjustment on the pushrod.... and says turn 1 3/4 turns from slack
    how do i tell..... 1. are they fucked?
                                2. what they are?
                                 3 how do i adjust them?
  • seaeagle
    seaeagle
    found out 2 things today..... 1st , i waas turning the motor over to adjust each one, without bleed down time... and wait for it...adjusting the wrong way...doh...
    back to the shed and hope for the best ...lol
     the adjust screw when taken out , theres nothing eles in there.... cant find any ball or spring, i dont get the bleed down thing...
    where are ya dave?????
  • seaeagle
    seaeagle
    scotty, so is there a number of turns to turn it or can it be done by hand?
  • kickinon
    kickinon
    yes they are solids, nothing wrong with solids, quicker to adjust, if your not sure when the lifter is (off the cam for adjustment,) the other rod on the same head will be at its highest point,( full open valve), remove all 4 cover retaining clips & lift the covers up hold them up with wire so you can watch each rod on its stroke..if you have a kicker that makes it even easier,,,remove both spark plugs as well, ..start on the front inlet..turn the motor over till the lifter is off the cam , thats when you will have the most (play)..the front outlet rod will now be at its highest point, if you keep turning the motor over and it starts going down you have gone to far, you want the oposite rod at its highest before you adjust the rod you are on, move on to the rear head...same deal...as scotty sais no appreciable play in rod just sos it turns, sometimes theres a slight bow in the rod, doesnt take much for that to happen,you will notice this when you have adjusted it and rotate it to see it does turn..and is seated correctly...l leave about a cigarette paper thickness of play in the up/down movement to allow for expantion...
  • seaeagle
    seaeagle
    i was not sure if they were hyd. or solids...this is all very new to new....
    ok, so they are solids...kool, ive got it running, but its popping/farting, would that be coz the valve timing is out abit? the points wouldnt need adjusting if its only had the heads done?correct me if im wrong....
    after reading what u put up kickinon, i think i know where i could have gone wrong, when it said opposite in the book i took that as meaning inlet - inlet, so when front inlet was up adlust the rear inlet.....fuck ...back to the shed again....lol
  • seaeagle
    seaeagle
    can soilds fuck up?
  • seaeagle
    seaeagle
    had a real hard time getin the intake manifold in , it has o rings and clamps, could it be air geting sucked in? making it pop and crackle
  • kickinon
    kickinon
    definitly look at timing,after you have adjusted the lifters, (advance / retard ) at the points, usualy after puish rod adjustment they also will need adjustment, as timing has been adjusted!
    dont forget to put a match head of grease on the cam lobe,sos the points dont ware prematurly,
  • seaeagle
    seaeagle
    ok, looks like its all good with the liffters....thanks for ya help fellars....got a little oil light staying on problem..any ideas???
  • kickinon
    kickinon
    if its at idle thats o.k.... if not then 2 things, either your sender and/ or wiring need to be looked at or you have an oiling problem, low presure usualy if the lights on anything above idle...
  • seaeagle
    seaeagle
    all done.... oil flowing good, light off. thanks again everyone
