Online: Humbug, beaglebasher
  • 08roadking
    08roadking
    does anybody know if i can put apes on 08 roadking
  • Hoodaman
    Hoodaman
    I have seen that done mate.......want to do it to my 08 as well they really look the chop.............also i have asked Big Joes Choppers and yup........can do.........
  • Fr3d
    Fr3d
    Besides having a bar that has the slots cut for the twist grip sensor, getting a twist grip sensor with a long enough cable to reach to nacelle is all you need. I put in a new sensor on mine and the cable length was good enough for the SE Beefy bars with plenty to spare. You will have to check with HD for the cable length.
  • robert65
    robert65
    nice choice 08rk ya won't be dissapointed very comfy position.
  • 08roadking
    08roadking
    thanks to all that helped next is were do i get them fitted in sydney
  • twincam88b
    twincam88b
    Isn't there a limit how high you can go with ape hangers, bloke here in SA has been defected for AH's. Oh yeah it's SA, we are treated like crims here, I forgot.
  • Hoodaman
    Hoodaman
    like everything TC, its the thrill of getting away with it....for a while.....
  • robert65
    robert65
    i think anything over shoulder height is illegal. but if ya sit on a box ya can raise ya height.
