white wall tyres
  • Grubby
    Grubby
    Softail tyres white walls has anyone purchase these and found a good dealer and fair price
    Prefer Melbourne
  • blueystar
    blueystar
    ROAD SWEEPER WEARS WHITE WALL SHOES AND THEY ARE A PAIN IN THE ARSE TO KEEP CLEAN
  • Grubby
    Grubby
    skimp I dont think so I was quote $630 for metzlers fitted unreal ask dealer how much are they without the gold wrapping
    whoops
  • robcig
    robcig
    $473.80 thankyou very much!! Frasers Concord. (Long way from Melbourne I know). Stock Dunlop supplied and fitted. Works well as long as you check pressures regularly.
  • FLSTC
    FLSTC
    should also say that those lindall brake pads worka treat with ww's. i fitted front and rear ( courtesy of scotty ) , same time as i replaced my front metzler ww. travelled bout 10000k so far and havent had to scrub them ..... YEE HAH ! they are a godsend !!!!!! btw metzler ww are a bit more expensive than dunlop , and dont last as long , but they are stickier on the black stuff ...
  • KDh Kustoms
    KDh Kustoms
    I know Geelong Harley can get them dont know about $$$$ though
