tacho on a 07 Dyna
    good to see you girls working together.... have an 07 manual if you want to borrow Stix... or I could scan/email relevant bits
  • OSP1340
    OSP1340
    I hooked up a tach up to mine Stix and had to use the #3 pin. I couldn't get a signal from my spedo.
    It's not hard at all to hook up. Only took me 30 minute to hook up the tach and wire it up.
  • shfunky
    shfunky
    Its an Alloy Art  tacho mount, you can use whatever tacho you want, if you can get the mount, I have been sort of trying for several months without success, Alloy Art wont answer my emails, other outlets listed dont seem to have any either.
  • shfunky
    shfunky
    Thanks stix
  • wayco
    wayco
    I ,ve followed the post ,but am not sure if i need to tap into pin 3 on the ecm connector -as per shared project ,stix & others.
    I want to move gauges to the bars rather than the tank.
    i have an 07 deuce -& managed to get a sporty speedo /tacho kit 67182-04 which comes with a wiring loom & warning lights and bracket.
    For gauges I'm using an 04 up road king tacho & 09 Rocker speedo.-hopefully they're compatible?
    Will i fuck anything just hooking up the gauges using the sporty wiring loom-most pins/wires seem in the same place?
    It seems even the dressers & fxd dyna's don't seem to use pin 3 as per uncle Ho's wiring diagram for taco yet flst 3 tacho does?
    Any advice appreciated.
    Cheers Wayco
