Online: John.R
2008 1200C, Rear Shocks
  • Midnite
    Midnite
    I weigh around 110kilos and have notice going over a hard bump in the road that the shock just goes through my back!
    1. If i adjust the preload more as if you were to when having a passanger, will this help to dampen the effect?
    2. Changing the shocks to something like bitubo? can i raise and lower the height?
    3. What brands with prices does everyone recommend and why?
    Cheers Midnite
  • MapleLeafs
    MapleLeafs
    I'm a certified waif around the same specs as you, Midnite ;) I have the same year and model bike. I haven't gotten off with any backpain yet, but I noticed some bumps on roads I know are best avoided for comfort's sake. Wouldn't hurt to play with the preload.
    Also as shovelhead recommends - you don't have apies do you? They seem to straighten up your back and allow more jarring.
  • Midnite
    Midnite
    Hi Mapleleafs,
    No i dont have ape hangers, but S.A. roads arent the best!! i going up the preload and see if that helps
  • Midnite
    Midnite
    Hi rodders, upped the preload - much better!! thank you
