CAM PROFILES -- WHAT, WHERE, HOW
  • GREG
    GREG
    18 years ago
    There has been a fair bit of discussion on CAM PROFILES over the last few weeks, so I thought I'd start a thread that will hopefully become a place where you can get your cam related questions answered as well as have a look at what workes for others.
    So if ya have changed your cam could you post some info about how it all went. The info could include but is not limited to:
    Make and profile of cam;
    What type of engine fitted to;
    What rev range is the cam best suited;
    What the bike is mainly used for (Touring, drags, fast town bike, coffe shop blasts etc)
    Any other modes done (cam related, ie adjustable pushrods, roller rockers, gear drive etc)
    Any other info you think would help.
    Thanks for your comments. I have added a Andrews cam profile table for a bit of a reference, if ya have something similar post it up.
    Greg
  • GREG
    GREG
    18 years ago
    Part #
    Grind
    Timing(*)
    Duration
    Valve Lift
    Lift @ TDC
    Springs
    Application
    .053
    .020
    Stock
    Intake
    -3.5/40
    216.5
    256
    .474
    .087
    Stock
    Stock '06 cam data listed for reference: All 2007 Twin 96" and '06 Dynas are fuel injection only; no carburetors.
    Exhaust
    41/-1.5
    219.5
    259
    .474
    .110
    216321
    21H
    10/30
    220
    255
    .498
    .134
    Stock
    Bolt-in cams: 88 and 96 inches - more torque for heavy bikes. Intended for stock compression ratios and pistons. Similar to #23 cam for EV80. (1700-4800 RPM).
    40/08
    228
    264
    .498
    .121
    216326
    26H
    11/35
    226
    262
    .490
    .138
    Stock
    Bolt-in cams: 88 and 96 inches - stock compression ratio. Great for two-up touring, this cam will add torque and HP at lower and middle RPM ranges. (1800-5200 RPM).
    41/09
    230
    266
    .490
    .112
    216331
    31H
    10/46
    236
    272
    .510
    .131
    Stock
    Great cam for motors with 95+ inches and 10.1 CR. Lower TDC lift for easy installation. Similar to 37G but different timing. (2000-5800 RPM).
    52/08
    240
    276
    .510
    .120
    216337
    37H
    18/38
    236
    272
    .510
    .171
    Stock
    Hot street cams for 88, 96 or 103 inches. 80+ rear wheel HP possible with well-tuned motors. Smooth idle, broad torque (2200-5600 RPM). Stock to 9.5 CR.
    46/14
    240
    276
    .510
    .148
    216344
    44H
    21/41
    242
    279
    .495
    .182
    Stock
    For 88, 96 or 103 inches and 9.5+ CR. Max. torque and HP at mid and upper RPM. (2300-5800 RPM).
    49/17
    246
    283
    .495
    .158
    216350
    50H
    20/48
    248
    283
    .510
    .184
    Stock
    Designed for easy installation in 96-103 inch motors with stock heads and 9.5 to 9.8 CR. (2400-6000 RPM).
    54/18
    252
    287
    .510
    .168
    216355
    55H
    22/46
    248
    283
    .550
    .197
    Hi-lift
    Great cams for 95-103 inch engines with 9.8 to 10.2 CR. Max HP - torque at mid and upper RPMs. (2600-6200).
    58/22
    252
    292
    .550
    .181
    216360
    60H
    24/56
    260
    296
    .560
    .205
    Hi-lift
    For well-prepped 95-103 inchers with 10.0 to 10.5 CR, 100+ HP is within reach. (2700-6500+ RPM).
    58/22
    260
    296
    .560
    .205
    (*) Timing and duration listed for .053 cam lift.
  • GREG
    GREG
    18 years ago
    Cheers Rats
    Can anyone tell me what is the maximum lift that standard valve springs will take and remain durable?
    The andrews table suggests a lift of about .510 before you need to go Hi lift.
    Can someone shed some light on overlap / duration between intake and exhaust? I'm not sure I completely understand reading of the tables?
    Greg
  • GREG
    GREG
    18 years ago
    Good steal wayne, thanks.
    RT - its on the cards, just seeing what others have done and trying to learn heaps.
    It all started with the T/Max, now the bug has bitten!!
    Greg
  • GREG
    GREG
    18 years ago
    Thats the plan mate. I like to have a go and am constantly mucking around with something. Its just that this something cost a lot more coin to start with which is why all of the annoying questions, but hey thats what it is all about. Enjoying the process, learn new stuff to keep the old grey matter working and having a good time doing it.
    Stix thanks for the reply, can you enlighten me on the 30 thou head gasket. What was the purpose (raise compression?)?
    RT - love the coffee sessions, it gives something new to plan each time. The wallet pain is the sort of pain ya get used to with these things I'm finding out!!
    Greg
  • GREG
    GREG
    18 years ago
    Thanks for the tips wayne, much appreciated.
    Greg
  • fredouil
    fredouil
    18 years ago
    i will install the wood's tw6-6 (+Thundermax AT) as soon i get my dresser.
    these cams are boldt-in and designed for torque, low -medium, those who are using them seem very impressed :
    http://www.woodcarbs.com/06-07cams.htm
    have a look a this dyno with just these news cams + exhaust http://groups.msn.com/HarleyTechTalk/dynoruns.msnw?action=get_message&mview=0&ID_Message=1219863
  • fredouil
    fredouil
    18 years ago
    no wonder their High Lift cams are noisy, they are set at 0.650 !!!, that moves, baby.
    i am going for the bolt-in ones set at 0.510, that should be fine or there is something wrong.
  • GREG
    GREG
    18 years ago
    Hi Fredouil
    You will be happy with the T/max. I am stoked with what it has done for my bike. I want to put cams in that will liven up things a little and help keep it cool as well.
    Greg
  • Deadly
    Deadly
    18 years ago
    Has anybody got specs on the Andrews 54, heard good things but can't find em even on the Andrews web site.
  • GREG
    GREG
    18 years ago
    The Andrews 54H is looking good, and the RPM range fits in well with where I spend a lot of time. I'm still working out what I want. I'm a pretty lazy rider these days and like to cruise along at a reasonable clip but have plenty in reserve for passing B-doubles in a hurry.
    Ive just had another check of the warrenty info page downloaded from the T/max. Most time spent at 2200 RPM. Some great info in there!!! Also moniters head temps and how long at each temp. The more I muck around with this thing I'm finding interesting things. I'm about to adjust the air fuel ratios Vs throttle position sensors to enrichen the AFR a little bit to see if temps come down a bit more.
    Greg
  • GOZZ
    GOZZ
    18 years ago
    Hey Stix 68.
    What sort of HP & TQ figures are you pulling on that setup of yours?
    GOZZ
  • GREG
    GREG
    18 years ago
    Come on all of you modifiers out there, The silence is deffening. What cam have you put in that works, I wont tell everyone your secret HP recipe!!!
    Or is everyone happy with their stock EPA choked POS cam?
  • GREG
    GREG
    18 years ago
    I'm pretty sure I'll go with the Andrews 37H at the moment. The 54H is also very interesting, but it comes on a bit further up the rev range (comes on later goes on for longer) than what I'm looking for I think.
    Should have the cam in by the end of March.... I'll let you all know how it goes.
    Greg
  • GREG
    GREG
    Any new cams fitted? and HP gains that ya want to let us know about.
  • andij
    andij
    my stock 96 87hp 101tq with bolt in cam at 510 lift and pushrods ,with the exhaust,aircleaner,pc111,todd at pattos dyno reckons nearly 100.hp and 103 tq.without any major engine work,no change to cr,more fun in rebuilds like stixs and scottys ,but the power only good on the straights,nutts a mate had andrews 60s is changeing to 54s as not matched well with 103 ,so we ll havr agood performance site soon so keep it up fellas ,it depends on how you ride stixs is drag style ,rt is distance long hauls ,i like twistes ,3 different styles ,3 different motors so look for where you ride before u choose
  • andij
    andij
    yeh scotty theyll be my choice wen times come to upgrade ,torq is great and 54s are gonna be a bench mark soon
