Difference between dyna frames - wideglide and lowrider??
  • wazza-in-oz
    wazza-in-oz
    Was wondering if someone can tell me is there any difference between a 1992 Dyna low rider frame and a 1992 Dyna Wide glide frame.  I know the front end is different but just ignore that for now.  Just need to know if there is any other difference between the frame and rear swingarm???  Also does anybody know if you can put a wide arse kit on a 1992 Low rider frame so you can put a fat tyre on?  Cheers.
