suppliment 12v power point
  • Hoodaman
    Hoodaman
    Just bought the HD power point that plugs into an available power supply to give a lighter type socket.......
    labled as touring and for FLHR models only to open it up and find it states not for Road King Classic...........work that out......and no HD part available for the FLHRC.
    now i didnt think there was much diff between the custom and classic so does anyone know why i caNT use this on my ride????
    looks like i may have to bodge a skt in from K bloody mart to get what i need which is to power the GPS..........
    any ideas ??
  • blueystar
    blueystar
    TELL ME MORE ABOUT THIS GPS I THINK BEEZA LOOKING FOR ONE
  • JD
    JD
    just get a long cord and hook it too the mains
  • PigironBob
    PigironBob
    Just hook it straight to the battery with a in line fuse.
  • imoo6170
    imoo6170
    Most of the guys I know with a GPS have had a mounting bracket installed on the handlebars and hard wired that in (as suggested earlier). Then they just plug in / remove the actual GPS. Admittly most have Dressers but a couple have Hertiages.
  • Fr3d
    Fr3d
    If it is kit number 91843-97, I have used one on my 08RKC and mounted it on the top of the right hand side cover. It plugs into the accessory plug next to the battery and is controled by the left hand toggle switch on the nacelle cover. I have been using it for heated clothing and gps on occasion and have no issue. I could not get a straight answer from the dealer and I could only think that if you have abs on your bike the module would get in the way of mounting the power supply on the left hand side?
  • gonzo
    gonzo
    Hi Hooda.
    I bought the kit (91843-97) and fitted it to my 07 RKC. Works fine. The instructions SAY it's not for the bike, but I only bought it to get the plug to fit the aux supply socket under the seat. I cut off the cig-lighter socket. I think the problem with it "not fitting" the classic may be that the side covers may be different??? Dunno. You're supposed to drill a hole thru one cover to fit the cig-lighter socket.
    If you still want to use the lighter plug attached to the lead on your GPS, I think you could probably tape the socket inside one of the side covers with the GPS plug inserted, and then run the wires to the handlebar area. Alternatively, there's the pocket in front of the battery, between the frame tubes (just below your nuts) and just behind the rear cyl head that's vacant. Plenty of room for the socket and plug there.
    One thing - if you're going to use the lighter socket/plug combo, I've found that they come apart with vibration. So, get a stout rubber band and loop it in a figure-8 over the connected plug and socket to hold them together.
    Gonzo.
  • Hoodaman
    Hoodaman
    onya fellas thanx for that.
    Gonzo ur right on the money mate thats exactally what i wanna do with it..I had a suspision the only prob mounting in the cover but i didnt want that.Thanks mate problem solved....
