want to remove baffles
  • biggzy
    biggzy
    g'day
    would apreciate some advice,i have currently got screaming eagle slip ons on my street bob and the dealer told me icould pull the baffles out when ever i wanted.i have tried but can't seem to succeed,help please.
  • biggzy
    biggzy
    thanks scotty will try again!
  • black29d
    black29d
    biggzy
    they just pull out, can be tight the first time you try to remove them.
    you can buy replacement baffles for them from J&P CYCLES that have the extra hole and the flap opened already, so you can keep the standard ones just in cases you get pinged
  • banjo48
    banjo48
    I got mine out with a slide hammer, with a hook on the end.
    My dealer service dept. told me to remove them and cut the "holey" bits off with a hacksaw. I did this but found the result far too noisey! not a nice deep roar, just loud and horrible (also gave me a headache!)
    So I welded the ends back on, and drilled out all the holes to 12-13mm. not perfect sound, but much better than before.
    I am still not 100% happy so will replace mine with some V&H big radius, as in my opinion they sound great. Just got to raise the $ first.
    2007 FXST
    SE slipons
    Bigsucker
    TMax
    Mustang seat
    61/2" Risers
