Online:
beaglebasher
Hard Wiring GPS?
Hard Wiring GPS?
STEAMER
1 year ago
Used my battery minder lead/plug. Can buy the plugs from supercheap or Jaycar, this way i unplug when no using gps. If you do wire direct to battery, add an inline waterproof blade fuse and a switch to turn power off when not in use or will drain battery over s period of time
John.R likes this post
John.R
1 year ago
Headlight or taillight circuits are generally the most used "switched +12v" circuits.
Or if it's a new m8 there's a USB port under the tank.
steelo
1 year ago
It can be an easy process WB. I wasted time once with the spare headlight wire (somewhere near the headstem) and it wasn't a long term fix.
The Garmin GPS usually comes with a reasonable length cable.
A ram Mount can give you some flexibility to move and position the GPS
Buy a fuse jumper from Jaycar (probably about $10)
Run the whole cable under the tank back to the fuse box, use the fuse jumper on the accessories circuit. If the fuse box cover won't close, drill a small hole in the cover and pass the red wire through. The earth can be attached anywhere.
Ram mounts come in a variety of mounting options
Jumper fuse installed
Jumper fuse
wombat457 likes this post
Daffy
1 year ago
Hi I just wire some heated grips. Found a blue wire under the seat and tapped into that with a scotch lock. The positive wire that is Just put the earth to a bolt nearby. Hope that helps. If you have a light you can poke the spikey end in to the wire and clip the other to earth to see if it’s live when you turn the ignition on.
steelo likes this post
Pedro123
1 year ago
Wombat, you thout of hard wiring a cig lighter/usb port instead?
Charge anything then!
Grease Monkey
1 year ago
What year and model Wombat?
Grease Monkey
1 year ago
Nice, big headlight narcel so pretty easy to stash a couple of relays.
steelo
1 year ago
An engineer friend once cautioned me against “paralysis by analysis”
Try something! Simpler the better. Thread 5 days old now.
steelo
1 year ago
Garmin’s instal video doesn’t mention an aux circuit for ignition on/off. They connect straight to terminals and say no additional fuses required. I’m with you. Must have ignition functionality.
STEAMER
1 year ago
For the same of about $10, i would just add a waterproof inline fuse. I think i used a 5amp,
wombat457, tussuck and Baloffski like this post
steelo
1 year ago
Well done WB.
Now, at the risk of making myself look like an ass.
Get one of those fuse jumpers for your installation.
You find a fuse in the fuse box that is ignition switched. You pull that fuse out and replace it with the jumper (the original fuse goes into the jumper for that circuit) You get a second fuse (2amp if you like) for the pigtail (power out wire) from the jumper.
Simply attach your red wire to that, black to earth and the job is done. Best of all worlds. If you install other accessories like a USB charger / phone charger, connect it to the same wire and bump up the fuse a bit.
For information, that inline breaker box may cut the power to the GPS when it detects no charging voltage going to battery.
steelo
1 year ago
Hey Wombat. The GPS installed yet? Show us some pics.
© 2024, v3.1.0
