Online: tussuck, Nilo, Burnzi
1&1/4" Bars
  • GREG
    GREG
    Looking to fit larger diameter bars so I can run the wiring inside and get a beefier look. Got quoted at about 2 hours labour to fit. Did any of you guys fit your own and were there any problems? I have read that getting the pins out of the plugs can cause some bother. Any tips would be good.
    Greg
  • GREG
    GREG
    I'm not decided on what bars to go with at the moment, most likely go with a bar of similar height but more width. I don't want to have to change cables just yet as braided lines will be fitted eventually.
    Whats the trick with the connectors?
    Greg
  • GREG
    GREG
    Thanks Scotty the attachment is much appreciated.
  • GREG
    GREG
    Yeh, I was thinking of using a thin pin punch. Thanks for the tip nobody.
  • SOFTY
    SOFTY
    Hi mate,
    I fitted fat t bars to mine! there 1 &1/4" and they were a bitch to install! however the result at the end when firring up me softy was the best feeling ever! my bars have 10" rise also! every cable i used is stock!!! wiring the switches was the hardest and had to extend the wires a tiny bit! make sure you solder the wires and use heat shrink over the wires! unless you wanna go through 5 boxes of 15amp fuses waiting for it to fix its self clearly like i did!
    I can send you a photo of mine if u like
  • GREG
    GREG
    Hey Softy
    Post up pic mate, always keen to see what others have done!
    Greg
