Online:
paulybronco, baldy1450, FONTANA302
Softail Speedo Drive
Jack2
2 months
Can the left hand speedo drive be dismantled? I need to reduce the length of the spacer to suit a different hub.
Cheers, Jack2
2 months
If you’re talking about early softail evo till 95 you can get them machine down a bit
I can’t remember the exact amount I’ve had two done several years ago to
Center the wheel more , you May have to centre the brake caliper to brake disc too
A good machinist can take some off both inner and outside
© 2024, v3.1.0
