Online:
paulybronco, baldy1450, FONTANA302
Error Code issue
Error Code issue
GGUser580
3 months
Hi all, Hoping to get some help solve a couple of issues with my 2014 Night Rod.
First issue is that I had Error codes P0132, P0134, and P0152. When I went to clear these codes the screen did not return noneE as excepted. What it now does when I press and hold the reset button is displays blank for a while and then comes back with No Rsp.
I know the obvious cause of this is the switch not being in the 'Run' position. This is not the case.
I cannot get a response from the 'p' fault like I can from the rest of the codes.
Has anyone come across this before or do you know what could be causing it. I need the codes cleared to troubleshoot another problem.
Thanks for any help that comes back..
beaglebasher
3 months
Sorry mate , cant help you . There is usually a couple of nerds that will explain the codes.
You might have to wait a couple of days but.
If you introduce yourself a bit better you might have more luck.
© 2024, v3.1.0
